Google Pixel 10 Pro XL
Resetting network settings
If you have problems using network configurations on your phone, such as mobile data, Wi-Fi or Bluetooth, resetting the network settings may help.
Press System.
Press Reset options.
Please note that all saved APN connections, you've created, are deleted.
Press Reset mobile network settings.
Press Reset settings.
Please note that all saved Wi-Fi and Bluetooth connections and passwords, you've created, are deleted.
Press Reset Bluetooth and Wi-Fi.
Press Reset.
