Google
Pixel 2
Google Pixel 2
f-273a3652-bfac-4b91-b9b4-e5ae5f92b51f
f-4d1b6746-83ef-4462-83c3-7dc367e1c0c3
f-7e5a85c4-9f18-4dd0-a48a-98e4ef078fb0
f-5ac567ae-a9f3-4a72-bbab-e502e94112e1
f-b70c814d-b025-4b1a-835d-09d0c3f94cf1
f-5fb8701b-883a-4186-a8e0-ea1c3954db7c
Can you make a voice call?
