Google Pixel 2
Solution 2 of 2: Wi-Fi hotspot isn't used correctly
When you use your phone as a Wi-Fi hotspot, you can share your phone's internet connection with other devices via Wi-Fi. To use your phone as a Wi-Fi hotspot, you need to set up your phone for internet.
Press Network & Internet.
Press Hotspot & tethering.
Press Set up Wi-Fi hotspot.
Press the field below "Network name" and key in the required name.
Press the drop down list below "Security".
Press WPA2 PSK to password protect your Wi-Fi hotspot.
Press the field below "Password" and key in the required password.
Press SAVE.
Press the indicator next to "Portable Wi-Fi hotspot" to turn on the function.
