Google
Pixel 2 XL
Google Pixel 2 XL
f-851891aa-ef6c-4860-bbde-c06da94947ed
f-997349b1-7b90-4847-9f62-119f5eac5069
f-438522fd-5401-4fcf-adc4-c5ddf2ca396f
f-41a3ccdb-6ac6-4e3d-8c57-dd45b264968e
f-26eee80e-6a6b-47d7-9c01-d3ab54b41d2a
f-7b2d0a65-1790-433d-97a0-4adb317acc64
Can you make a voice call?
