Google
Pixel 3a XL
Google Pixel 3a XL
f-731a901e-06c3-44bc-9ce4-1e508155f34b
f-57eeced3-a0e5-4241-a723-04fb36e8b279
f-27748b55-08fe-4487-b051-c0032f7becbf
f-8c34e1e4-dc89-462e-916f-14daadf44ee1
f-5c92c606-cd23-4552-abe0-2fb4577e1a97
f-193359b3-5c38-45d8-851f-c0bea8b35fa1
Solution 1 of 2: The password used on the other device is incorrect
To use your phone as a Wi-Fi hotspot, you need to key in the password you selected when you set up your phone as a Wi-Fi hotspot on the other device.
Check the password for the Wi-Fi hotspot on your phone and key in the correct password on the other device.
