Google
Pixel 4
Google Pixel 4
f-734f72ee-59b2-4aae-b33b-a4719f5fd0c9
f-7992fad8-69e6-4580-94a0-9c5b31721a5e
f-bb02dcc1-6b97-4a17-ac73-a237def01a75
f-6bf642f5-a3c1-485c-9f9f-d2544de814d5
f-282b2f22-3c07-4045-a253-19be4d190fba
f-d96c6d40-b968-4979-a54f-c9262e298263
Can you make a voice call?
