Google
Pixel 4 XL
Google Pixel 4 XL
f-126d52d4-1dd5-412e-901e-44106fc9bac9
f-32c7287f-28ac-40a2-9e15-7b85e9a20737
f-2c51eb6b-149f-44f3-b3bd-2f00a6a975e1
f-4472ddc8-6f1a-40c6-8ad0-68b32e4a60ea
f-bde3279d-f4af-43d8-94e0-77d9052f9681
f-ef77e600-6459-42ce-9215-c9010d859ada
Can you make a voice call?
