Google
Pixel 5
Google Pixel 5
f-85e245c2-49f3-4ba5-a468-19885b2a12f5
f-d179a928-2af1-4ecc-891c-8f2992040f73
f-b42fd2c9-de8f-4514-9b49-f6404cea6990
f-405c4984-fd21-4ed5-bc29-57d803bc99f8
f-e03a5b3f-b7f4-4f57-84f6-85bfc7703d19
f-10681a4b-a3a0-4d8f-a7fe-227728260f9b
Solution 1 of 2: The password used on the other device is incorrect
To use your phone as a Wi-Fi hotspot, you need to key in the password you selected when you set up your phone as a Wi-Fi hotspot on the other device.
Check the password for the Wi-Fi hotspot on your phone and key in the correct password on the other device.
