Google
Pixel 6
Google Pixel 6
f-2b64f47e-0be2-4adc-a3eb-fb153e811879
f-54fec409-0dbf-471f-965f-e2e09955e270
f-00fa7e31-08c9-4add-a4be-8a9053f3db40
f-ca2c112c-3c34-460d-8c84-d4a336c86c32
f-67844014-c675-4541-afe6-4b6a54a90516
f-e2221731-6f4c-439f-8abb-15a71fc836f7
If you can't send and receive picture messages, there may be several causes of the problem.
It's important to find out if you can make a call. If you can't make a call, you need to solve this problem first. When the problem is solved, you will most likely also be able to send and receive picture messages.
Can you make a voice call?
