Google
Pixel 6
Google Pixel 6
f-2b64f47e-0be2-4adc-a3eb-fb153e811879
f-54fec409-0dbf-471f-965f-e2e09955e270
f-00fa7e31-08c9-4add-a4be-8a9053f3db40
f-ca2c112c-3c34-460d-8c84-d4a336c86c32
f-67844014-c675-4541-afe6-4b6a54a90516
f-e2221731-6f4c-439f-8abb-15a71fc836f7
Solution 1 of 2: The password used on the other device is incorrect
To use your phone as a Wi-Fi hotspot, you need to key in the password you selected when you set up your phone as a Wi-Fi hotspot on the other device.
Check the password for the Wi-Fi hotspot on your phone and key in the correct password on the other device.
