Google Pixel 6 Pro
Solution 2 of 2: Wi-Fi hotspot isn't used correctly
When you use your phone as a Wi-Fi hotspot, you can share your phone's internet connection with other devices via Wi-Fi. To use your phone as a Wi-Fi hotspot, you need to set up your phone for internet.
Press Network and Internet.
Press Hotspot and tethering.
Press Wi-Fi hotspot.
Press Hotspot name.
Key in the required Wi-Fi hotspot name and press OK.
Press Security.
Press WPA3-Personal to password protect your Wi-Fi hotspot.
Press Hotspot password and key in the required password.
Press OK.
Press the indicator next to "Use Wi-Fi hotspot" to turn on the function.
