Google
Pixel 6 Pro
Google Pixel 6 Pro
f-b5158561-b3bf-4f42-ba4b-409758fdab9f
f-5a0d9c28-eb8e-4e4b-ab8f-e04db24e3c73
f-93c3d4ba-de74-4fe6-a087-5fb9990ff30c
f-9741ea90-2fb5-4dc3-aed6-c9aa57a81c06
f-7b10b885-0d03-44f9-85a1-3ade29196319
f-2cf3a757-e01c-47da-ab2c-13eb7c89d887
Solution 1 of 2: The password used on the other device is incorrect
To use your phone as a Wi-Fi hotspot, you need to key in the password you selected when you set up your phone as a Wi-Fi hotspot on the other device.
Check the password for the Wi-Fi hotspot on your phone and key in the correct password on the other device.
