Google
Pixel 7
Google Pixel 7
f-f4653c36-e163-4248-951d-a633048d789e
f-e78407b2-48f8-4224-9753-8cb2128d5b26
f-71116c1c-9d22-4c9b-9a6d-5d3d089b45b4
f-5fdd77ca-333b-4cfc-8edb-78777d95783d
f-04334dda-ac5e-40a6-b180-e90efa210f35
f-ecd14ec7-bcc8-4796-80f4-e4a177d6c965
Solution 2 of 2: The password used on the other device is incorrect
To use your phone as a Wi-Fi hotspot, you need to key in the password you selected when you set up your phone as a Wi-Fi hotspot on the other device.
Check the password for the Wi-Fi hotspot on your phone and key in the correct password on the other device.
