Google
Pixel 9
Google Pixel 9
f-2cb88a95-2206-4d4a-a838-f0faa29ac456
f-56d2279b-cf24-4a9b-bc19-0ebd25a8b280
f-c68290b7-1693-478a-9b14-4fb9e581fe31
f-ad468a52-c5f0-4486-9008-e7e22cfe3435
f-1fe50a37-4b4a-45bc-af72-a1ac3f09ac94
f-86c01160-040c-4592-b0a8-88753a5e721a
f-76da7de7-2ccc-4c69-b90f-0dcf19fe70ed
f-939d56f9-d974-440e-8592-327272ddd668
Solution 2 of 2: The password used on the other device is incorrect
To use your phone as a Wi-Fi hotspot, you need to key in the password you selected when you set up your phone as a Wi-Fi hotspot on the other device.
Check the password for the Wi-Fi hotspot on your phone and key in the correct password on the other device.
