Google
Pixel 9 Pro
Google Pixel 9 Pro
f-eb255fd6-a239-4164-8a5b-1418685fcc9c
f-2630f40d-6a4d-4021-89a3-fc390b068a00
f-f5661f73-e372-4d5a-a9a8-95798d7cd4cd
f-8fa8851f-b47f-46ca-86c6-bf79ed604a86
f-1b9fe957-226a-457b-a989-26c1d28cbffe
f-222c8937-87ac-4ab6-bcb3-36dca1cfbd5d
f-1210f34d-089a-4eb8-adf8-c88649515745
f-747abf3a-fd37-4906-8276-0b83b1f3ced9
Solution 1 of 4: Wi-Fi calling is turned off
When Wi-Fi calling is turned on, you can make and answer calls using a Wi-Fi network when you're in an area with little or no network coverage. To turn on Wi-Fi calling, you need to establish a connection to a Wi-Fi network, select 4G (LTE) as network mode and follow the steps below. You can also visit the EE web page for more information about Wi-Fi calling.
Press Network and Internet.
Press SIMs.
Press SIMs.
Press SIMs.
Press the name of the SIM.
Press Wi-Fi Calling.
Press the indicator next to "Use Wi-Fi calling" to turn the function on or off.
