Google
Pixel 9 Pro XL
Google Pixel 9 Pro XL
f-02c96a73-c0fb-49fc-b34f-e4fc55609e83
f-92f25122-78da-4d7d-82a0-f4ea3004f664
f-9c66f362-f35d-480d-ada8-f05aef0de501
f-24149cab-c8db-4546-a4a5-02ca2f250374
f-cb281a96-d34e-4c8b-8afc-e4de3eea39c0
f-84b6e267-2281-41f8-9abf-a761e87fb7c0
f-1e8c9d5f-2129-4fca-871c-64638f45faef
f-8e3d4a34-d002-41c5-b9f1-903d110b9fcc
Selecting ring tone
You can select the ring tone you want to hear when you get a call.
Step 1 of 9
Step 2 of 9
Press Sound and vibration.
Step 3 of 9
Press Phone ringtone.
Step 4 of 9
Press the required category.
Step 5 of 9
Press the required ring tones to hear them.
Step 6 of 9
Once you've found a ring tone you like, press SAVE.
Step 7 of 9
To use a different ring tone than the default ones, press My Sounds and follow the instructions on the screen to select the required ring tone.
Step 8 of 9
Step 9 of 9
