Google
Pixel 9 Pro XL
Google Pixel 9 Pro XL
f-02c96a73-c0fb-49fc-b34f-e4fc55609e83
f-92f25122-78da-4d7d-82a0-f4ea3004f664
f-9c66f362-f35d-480d-ada8-f05aef0de501
f-24149cab-c8db-4546-a4a5-02ca2f250374
f-cb281a96-d34e-4c8b-8afc-e4de3eea39c0
f-84b6e267-2281-41f8-9abf-a761e87fb7c0
f-1e8c9d5f-2129-4fca-871c-64638f45faef
f-8e3d4a34-d002-41c5-b9f1-903d110b9fcc
Solution 2 of 2: The password used on the other device is incorrect
To use your phone as a Wi-Fi hotspot, you need to key in the password you selected when you set up your phone as a Wi-Fi hotspot on the other device.
Check the password for the Wi-Fi hotspot on your phone and key in the correct password on the other device.
