Google
Pixel 9a
Google Pixel 9a
f-c35aa2d7-03a3-4fac-b2e4-684704e0d94a
f-e583ad98-2e92-4857-9a03-ab3d96fb4646
f-1d764f20-07a0-4f2d-aac1-2d9a184d8c82
f-2110be86-fd47-45e2-8a64-a27174927e1a
f-27982d45-d313-444d-a3bc-902878e377f3
f-a4d33411-c42d-4343-ba35-cb519cf38a6c
f-1b32f7fb-4034-4e6f-a584-d7d8816b392d
f-17ebdd3c-6e06-49da-8ca7-9a0e6d9c453b
Solution 2 of 2: The password used on the other device is incorrect
To use your phone as a Wi-Fi hotspot, you need to key in the password you selected when you set up your phone as a Wi-Fi hotspot on the other device.
Check the password for the Wi-Fi hotspot on your phone and key in the correct password on the other device.
