Google Pixel Watch 2
No ring tone is heard on incoming calls
Solution 1 of 1: Do Not Disturb is turned on
If you don't want to be disturbed, you can turn on Do Not Disturb on your smartwatch. You will not receive calls, messages or notifications.
Press the Do Not Disturb icon to turn the function on or off.
Press the crown to return to the home screen.
