HONOR 400 Pro
Solution 4 of 5: GPS position usage for applications is turned on
Press Location.
Press the indicator next to "Use location" to turn the function on or off.
Press Location Accuracy.
Press arrow left twice.
Press Apps.
Press Manage apps.
Press the required app.
Press Permissions.
Press Location.
Press the required setting.
