HONOR 400 Pro
Using HONOR AI on your phone
HONOR AI allows you to use many of your phone's functions in a smarter and more efficient way. Here you can see some examples of HONOR AI usage. To use most of the HONOR AI functions, you need to activate your HONOR ID on your phone and set up your phone for internet.
Go to the required picture.
Draw a circle around the required object on the picture using your knuckle.
Press the required app and follow the instructions on the screen to use the function.
Slide your finger right on the screen to return to the picture.
Open a supported app, such as Notes, and key in the required text.
Press AI Notes.
To generate a summary of the text, press AI summary.
To generate a summary of a sound recording, press AI minutes and follow the instructions on the screen to use the function.
To format the text, press AI format and follow the instructions on the screen to use the function.
To use HONOR AI to translate a conversation, slide your finger downwards starting from the top right side of the screen.
Press AI Translate.
Follow the instructions on the screen to select the required language settings and use the function.
Press the gallery icon and go to the required picture or video.
Press AI Edit and follow the instructions on the screen to use the function.
Press HONOR AI.
More examples of Honor AI usage are now displayed.
