HONOR
Magic7 Pro
HONOR Magic7 Pro
f-1cfb15bf-2520-4ab0-87d7-b92e7b8a4bff
f-7ac95487-02bd-4279-b3b0-7e63bd0aa9a8
f-b3ba3f35-01b5-46d9-b4fb-004506ff2287
f-93efc050-4aa9-4373-bc57-611fa72ab9de
f-8f1ee642-4746-4915-bf4c-82244db4ab65
f-8eb697fc-aae3-4845-aa77-e491fcd4349c
f-13f768ee-493b-4b0b-928b-39700347dcd3
f-e4c8492a-cc72-42dd-9d9a-bbd59ac6e633
Can you make a voice call?
