HONOR
Magic7 Pro
HONOR Magic7 Pro
f-1cfb15bf-2520-4ab0-87d7-b92e7b8a4bff
f-7ac95487-02bd-4279-b3b0-7e63bd0aa9a8
f-b3ba3f35-01b5-46d9-b4fb-004506ff2287
f-93efc050-4aa9-4373-bc57-611fa72ab9de
f-8f1ee642-4746-4915-bf4c-82244db4ab65
f-8eb697fc-aae3-4845-aa77-e491fcd4349c
f-13f768ee-493b-4b0b-928b-39700347dcd3
f-e4c8492a-cc72-42dd-9d9a-bbd59ac6e633
Using HONOR AI on your phone
HONOR AI allows you to use many of your phone's functions in a smarter and more efficient way. Here you can see some examples of HONOR AI usage. To use most of the HONOR AI functions, you need to activate your HONOR ID on your phone and set up your phone for internet.
Go to the required picture.
Step 1 of 17
Using HONOR AI, you can draw a circle around an object in a picture and use sections of the picture in different apps. You can use the function in all apps that allow you to take screenshots. To use Knuckle Search, you need to turn on the function in Settings on your phone.
Draw a circle around the required object on the picture using your knuckle.
Step 2 of 17
Press the required app and follow the instructions on the screen to use the function.
Step 3 of 17
Slide your finger right on the screen to return to the picture.
Step 4 of 17
Open a supported app, such as Notes, and key in the required text.
Step 5 of 17
Press AI Notes.
Press AI Notes.
Step 6 of 17
Press AI Notes.
To generate a summary of the text, press AI Summary.
Step 7 of 17
To format the text, press AI Format and follow the instructions on the screen to use the function.
Step 8 of 17
To generate a summary of a sound recording, press AI Minutes and follow the instructions on the screen to use the function.
Step 9 of 17
Using HONOR AI, you can transcribe your sound recordings in the required format. To use the function, you must first have created a sound recording.
To use HONOR AI to translate a conversation, slide your finger downwards starting from the top right side of the screen.
Step 10 of 17
Press AI Translate.
Press AI Translate.
Step 11 of 17
Press AI Translate.
Follow the instructions on the screen to select the required language settings and use the function.
Step 12 of 17
Press the gallery icon and go to the required picture or video.
Step 13 of 17
Press AI Edit and follow the instructions on the screen to use the function.
Step 14 of 17
Step 15 of 17
Press HONOR AI.
Press HONOR AI.
Step 16 of 17
Press HONOR AI.
More examples of Honor AI usage are now displayed.
Step 17 of 17
