Huawei
Mate 20 lite
Huawei Mate 20 lite
f-00537029-fc04-45cd-8d5a-470e6329c8e2
f-371cef9e-4dac-42a3-8eff-8ddfb969de16
f-a876948a-926d-44b5-96e6-a25a27a69336
f-a5422bcf-1434-4e36-88a5-19118d4a908a
f-aa22e69b-61f4-4e15-836b-5021b953ff93
f-d6ed7c18-2e91-4b22-8581-9e90e835b352
Can you make a voice call?
