Huawei
Mate 20 Pro
Huawei Mate 20 Pro
f-1d144d36-4f25-4dbe-93b5-b780df621617
f-2180afee-a094-4759-8b8d-066db4f879fe
f-6a299b26-5970-4188-b719-6f6c3007fa20
f-3977e861-7b92-41bd-9743-30e8d0ac11a4
f-612629e0-bcb7-4966-8fb0-50bbb7277f17
f-6a77478e-845d-496b-ad00-d19a2097b152
Step 1 of 15
Press Security & privacy.
Step 2 of 15
Press Fingerprint ID.
Step 3 of 15
Press CHANGE UNLOCK METHOD.
Step 4 of 15
Step 5 of 15
Press DONE.
Press DONE.
Step 6 of 15
Press DONE.
Press New in-screen fingerprint.
Step 7 of 15
Press ENROL FINGERPRINT and follow the instructions on the screen to create the phone lock code using your fingerprint.
Step 8 of 15
Press OK.
Press OK.
Step 9 of 15
Press OK.
Press the indicator next to the required settings to turn them on or off.
Step 10 of 15
Press the Return key twice.
Step 11 of 15
Press Lock screen password.
Step 12 of 15
Press Disable lock screen password.
Step 13 of 15
Key in the current phone lock code and press DISABLE.
Step 14 of 15
Step 15 of 15
