Huawei
Mate 20 Pro
Huawei Mate 20 Pro
f-1d144d36-4f25-4dbe-93b5-b780df621617
f-2180afee-a094-4759-8b8d-066db4f879fe
f-6a299b26-5970-4188-b719-6f6c3007fa20
f-3977e861-7b92-41bd-9743-30e8d0ac11a4
f-612629e0-bcb7-4966-8fb0-50bbb7277f17
f-6a77478e-845d-496b-ad00-d19a2097b152
Uninstalling apps
You can uninstall apps to free up memory.
Press Play Store.
Press Play Store.
Press Play Store.
Press My apps & games.
Press INSTALLED.
Press INSTALLED.
Press INSTALLED.
Press the required app.
Press UNINSTALL.
Press UNINSTALL.
Press UNINSTALL.
Press OK.
Press OK.
Press OK.
