Huawei
Mate 20 Pro
Huawei Mate 20 Pro
f-1d144d36-4f25-4dbe-93b5-b780df621617
f-2180afee-a094-4759-8b8d-066db4f879fe
f-6a299b26-5970-4188-b719-6f6c3007fa20
f-3977e861-7b92-41bd-9743-30e8d0ac11a4
f-612629e0-bcb7-4966-8fb0-50bbb7277f17
f-6a77478e-845d-496b-ad00-d19a2097b152
Solution 9 of 11: Flight mode is turned on
You can turn off all wireless connections so your phone can’t cause any interference with sensitive equipment in a plane or a hospital. You can use many phone functions when flight mode is turned on, but you can't send messages or make calls.
Slide two fingers downwards starting from the top of the screen
Step 1 of 3
Press Airplane mode to turn the function on or off.
Step 2 of 3
Step 3 of 3
