Huawei
Mate 20 Pro
Huawei Mate 20 Pro
f-1d144d36-4f25-4dbe-93b5-b780df621617
f-2180afee-a094-4759-8b8d-066db4f879fe
f-6a299b26-5970-4188-b719-6f6c3007fa20
f-3977e861-7b92-41bd-9743-30e8d0ac11a4
f-612629e0-bcb7-4966-8fb0-50bbb7277f17
f-6a77478e-845d-496b-ad00-d19a2097b152
Turning GPS on or off
Press Security & privacy.
Press Location access.
If you turn on geotagging, your phone can find your position using GPS. If you turn off the function, you can't use any GPS functions on your phone.
Press Google Location Accuracy.
