Huawei
Mate 20 Pro
Huawei Mate 20 Pro
f-1d144d36-4f25-4dbe-93b5-b780df621617
f-2180afee-a094-4759-8b8d-066db4f879fe
f-6a299b26-5970-4188-b719-6f6c3007fa20
f-3977e861-7b92-41bd-9743-30e8d0ac11a4
f-612629e0-bcb7-4966-8fb0-50bbb7277f17
f-6a77478e-845d-496b-ad00-d19a2097b152
Solution 4 of 7: Your phone is locked to another operator
If your phone is SIM locked to another operator and you try to use a SIM from your operator, the display will tell that your SIM is invalid.
Before you can use a SIM from your operator, you need to unlock your phone using an unlock code. To get the unlock code, contact the operator that locked your phone.
