Huawei
Mate 20 Pro
Huawei Mate 20 Pro
f-1d144d36-4f25-4dbe-93b5-b780df621617
f-2180afee-a094-4759-8b8d-066db4f879fe
f-6a299b26-5970-4188-b719-6f6c3007fa20
f-3977e861-7b92-41bd-9743-30e8d0ac11a4
f-612629e0-bcb7-4966-8fb0-50bbb7277f17
f-6a77478e-845d-496b-ad00-d19a2097b152
Solution 1 of 3: The battery is faulty
If the battery is faulty, you can't turn on your phone.
Go to the manufacturer's web page to see if it's possible to change the battery.
