Huawei
Mate 20 X 5G
Huawei Mate 20 X 5G
f-47b9d78c-03c0-4230-bce5-bfe669971cab
f-aeb1f5b9-99d7-4f64-85e0-d31948fa551b
f-adc799d6-d29e-48c9-a4fa-9a17725a1b80
f-845bb7c9-ba8e-42d5-9135-51d41084a18b
f-bd7c1758-4255-4ee3-8b53-a87f6ba5ce5a
f-798a5d82-b2cc-4814-a964-1a9d1c62e23d
Can you use Wi-Fi?
