Huawei
Mate40 Pro 5G
Huawei Mate40 Pro 5G
f-35507320-aae9-49bb-9a4a-f6ca4d6f2985
f-8b097607-2120-4b49-be3a-747c833d8a2b
f-94809fc9-e145-4016-8462-42feda7aa8b4
f-12610498-0e62-48e6-b16c-8180039c39a8
f-86d2452d-a91a-4fb4-80ca-2e6f212fb4a9
f-54e7f797-64dd-436d-b4e3-10216d7990e2
Can you make a voice call?
