Huawei
Mate40 Pro 5G
Huawei Mate40 Pro 5G
f-35507320-aae9-49bb-9a4a-f6ca4d6f2985
f-8b097607-2120-4b49-be3a-747c833d8a2b
f-94809fc9-e145-4016-8462-42feda7aa8b4
f-12610498-0e62-48e6-b16c-8180039c39a8
f-86d2452d-a91a-4fb4-80ca-2e6f212fb4a9
f-54e7f797-64dd-436d-b4e3-10216d7990e2
Solution 15 of 15: GPS is turned on
Step 1 of 11
Press Location.
Press Location.
Step 2 of 11
Press Location.
Step 3 of 11
Press the indicator next to "Access my location" to turn the function on or off.
Press Location.
Press Location.
Step 4 of 11
Press Location.
Press the required app.
Step 5 of 11
Press the required setting.
Step 6 of 11
Press arrow left twice.
Step 7 of 11
Press Advanced settings.
Step 8 of 11
Step 9 of 11
Press the indicator next to "Wi-Fi scanning" to turn the function on or off. If you turn on the function, your phone can find your exact position using nearby Wi-Fi networks.
Step 10 of 11
Press the indicator next to "Bluetooth scanning" to turn the function on or off. If you turn on the function, your phone can find your exact position using nearby Bluetooth devices.
Step 11 of 11
