Huawei
MediaPad T5
Huawei MediaPad T5
f-afda6190-6e00-4510-84ce-d38fc4f41e8d
f-3438ef7b-27bc-4e44-96bd-56d59908b7b6
f-f75b1c00-4952-4822-8c08-f67bf3a3078c
f-e34983cb-533a-4055-8ba1-c1287cf1b373
f-b701f893-d954-400f-ae0d-2fe316630c41
f-a26c12a7-145d-4cc2-ae7e-7f3b55432530
It's not possible to turn on my tablet
Solution 3 of 3: Your tablet isn't turned on correctly
Before you can turn on your tablet, you need to insert your SIM into your tablet.
Press and hold On/Off until your tablet is turned on.
Step 1 of 5
If you're asked to key in your PIN, do so and press OK. The default PIN is 1111.
1111
1111
Step 2 of 5
Press and hold On/Off until a pop-up menu is displayed.
Step 3 of 5
Press Power off.
Press Power off.
Step 4 of 5
Press Power off.
Press Touch to power off.
Step 5 of 5
