Huawei
MediaPad T5
Huawei MediaPad T5
f-afda6190-6e00-4510-84ce-d38fc4f41e8d
f-3438ef7b-27bc-4e44-96bd-56d59908b7b6
f-f75b1c00-4952-4822-8c08-f67bf3a3078c
f-e34983cb-533a-4055-8ba1-c1287cf1b373
f-b701f893-d954-400f-ae0d-2fe316630c41
f-a26c12a7-145d-4cc2-ae7e-7f3b55432530
My tablet's battery life is short
Solution 9 of 9: GPS is turned on
Your tablet can determine your geographical position using GPS (Global Positioning System). The information about your location can be used by a number of applications on your tablet such as navigation, the search function or weather forecast.
Press Security & privacy.
Press Location services.
Press the indicator next to "Access to my location" to turn the function on or off.
If you select Use GPS, Wi-Fi and mobile networks, your tablet can find your exact position using the GPS satellites, the mobile network and nearby Wi-Fi networks. Satellite-based GPS requires a clear view of the sky.
If you select Use Wi-Fi and mobile networks, your tablet can find your approximate position using the mobile network and nearby Wi-Fi networks.
If you select Use GPS only, your tablet can find your exact position using the GPS satellites but it may take longer as there is no access to supplementary information from the mobile network or nearby Wi-Fi networks.
