Huawei
P smart 2019
Huawei P smart 2019
f-246920a5-3452-41ca-ae67-fee38127b1fd
f-e90a4d04-53b8-4212-9344-256f7b41cdf9
f-f7b24c4d-e042-4e2d-94bd-09c31144fc9e
f-a648d97d-7105-42ce-bdb2-973db4542ddb
f-f48a7a78-0389-42f8-8942-53374e9dd396
f-991a8ce6-0637-4ffd-8ba2-d13489c7c73b
Can you make a voice call?
