Huawei
P smart 2019
Huawei P smart 2019
f-246920a5-3452-41ca-ae67-fee38127b1fd
f-e90a4d04-53b8-4212-9344-256f7b41cdf9
f-f7b24c4d-e042-4e2d-94bd-09c31144fc9e
f-a648d97d-7105-42ce-bdb2-973db4542ddb
f-f48a7a78-0389-42f8-8942-53374e9dd396
f-991a8ce6-0637-4ffd-8ba2-d13489c7c73b
Selecting dual SIM settings
When you insert two SIMs into your phone, you can make calls and send and receive messages from both SIMs. You can also select a default SIM for mobile data usage.
Step 1 of 9
Press Wireless & networks.
Step 2 of 9
Press Dual SIM settings.
Step 3 of 9
Press the indicator next to the required SIM to turn use of the SIM on or off.
Step 4 of 9
Press the field next to “Default mobile data” below the required SIM.
Step 5 of 9
Press SWITCH.
Press SWITCH.
Step 6 of 9
Press SWITCH.
Press Default calling SIM.
Step 7 of 9
Press the required setting.
Step 8 of 9
Step 9 of 9
