Huawei
P smart
Huawei P smart
f-3409b79c-526b-48ac-bf7c-949cb0616fca
f-3252f76c-b4cd-450a-a13c-07772f2686e1
f-bb51db59-d25b-4676-a1a3-a259693cfb76
f-6602657a-53a7-4c27-9b99-f633b9280b55
f-d9e01cf5-79f2-4483-bd30-c994191e1244
f-d311467b-cd55-49b0-a9dc-7032d7d67e00
Can you make a voice call?
