Huawei
P20 lite
Huawei P20 lite
f-927705e8-b9eb-467b-8534-b31bd27e9bb0
f-6d649079-53ab-4a97-a1c6-3fba018ce384
f-59f66916-36e0-4796-8316-918735b704bd
f-b6426d21-396c-4ee1-994d-83ac33090c57
f-1ecff7e9-6eff-4e2f-b4c7-390745e5f02f
f-4c4b1624-87a4-4f71-8a71-496d8158c836
Can you make a voice call?
