Huawei
P20 lite
Huawei P20 lite
f-927705e8-b9eb-467b-8534-b31bd27e9bb0
f-6d649079-53ab-4a97-a1c6-3fba018ce384
f-59f66916-36e0-4796-8316-918735b704bd
f-b6426d21-396c-4ee1-994d-83ac33090c57
f-1ecff7e9-6eff-4e2f-b4c7-390745e5f02f
f-4c4b1624-87a4-4f71-8a71-496d8158c836
Solution 15 of 15: GPS is turned on
Press Security & privacy.
Press Location services.
Press the indicator next to "Access to my location" to turn the function on or off.
If you select Use GPS, Wi-Fi and mobile networks, your phone can find your exact position using the GPS satellites, the mobile network and nearby Wi-Fi networks. Satellite-based GPS requires a clear view of the sky.
If you select Use Wi-Fi and mobile networks, your phone can find your approximate position using the mobile network and nearby Wi-Fi networks.
If you select Use GPS only, your phone can find your exact position but it may take longer as there is no access to supplementary information from the mobile network or nearby Wi-Fi networks.
