Huawei
P20 Pro
Huawei P20 Pro
f-806e7c30-2377-4d0d-bc9c-94df783c6898
f-bc7d1280-493c-4452-a3c8-1ab84fbc6a43
f-94aa7a05-5551-4466-8afc-9c9914e94a0a
f-22c9aeb1-67c1-4dc1-8fec-6b634fa66c9b
f-2ab6ae4a-d340-4060-9af9-cff40e78144a
f-8f4b3b54-7163-4fbb-a566-3f0880eebe53
Solution 4 of 6: You're trying to check your voicemail when abroad
The default voicemail number can only be used if you're calling from your own network.
Call +447953222222 to check your voice messages when abroad. Please note that you need to set a PIN before you can check your voice messages when abroad.
