Huawei
P20 Pro
Huawei P20 Pro
f-806e7c30-2377-4d0d-bc9c-94df783c6898
f-bc7d1280-493c-4452-a3c8-1ab84fbc6a43
f-94aa7a05-5551-4466-8afc-9c9914e94a0a
f-22c9aeb1-67c1-4dc1-8fec-6b634fa66c9b
f-2ab6ae4a-d340-4060-9af9-cff40e78144a
f-8f4b3b54-7163-4fbb-a566-3f0880eebe53
Solution 11 of 11: The selected network is out of range
Step 1 of 9
Press Wireless & networks.
Step 2 of 9
Press Mobile network.
Step 3 of 9
Press Carrier.
Press Carrier.
Step 4 of 9
Press Carrier.
If you want to select a network automatically, press the indicator next to
Step 5 of 9
If you want to select a network automatically, press the indicator next to "Choose automatically" to turn on the function.
If you want to select a network manually, press the indicator next to
Step 6 of 9
If you want to select a network manually, press the indicator next to "Choose automatically" to turn off the function.
Press OK and your phone will search for networks.
Step 7 of 9
Press the required network.
Step 8 of 9
Step 9 of 9
