Huawei
P30
Huawei P30
f-69b58f9d-f654-400e-b659-5d568eed24e0
f-3bdb3c8d-c6b4-4971-9294-df1e0920f0de
f-f4c4a159-82a3-47cb-a831-994d81e2fc6e
f-eb942c60-a16c-4773-b526-eb0d937d4cee
f-42450ad5-7b2c-4675-800f-20e8ddc44bc9
f-17136568-0500-4cb1-8139-d35e1ae49a28
Solution 11 of 11: The selected network is out of range
Step 1 of 9
Press Wireless & networks.
Step 2 of 9
Press Mobile network.
Step 3 of 9
Press Carrier.
Press Carrier.
Step 4 of 9
Press Carrier.
If you want to select a network automatically, press the indicator next to
Step 5 of 9
If you want to select a network automatically, press the indicator next to "Automatic" to turn on the function.
If you want to select a network manually, press the indicator next to
Step 6 of 9
If you want to select a network manually, press the indicator next to "Automatic" to turn off the function.
Press OK and your phone will search for networks.
Step 7 of 9
Press the required network.
Step 8 of 9
Step 9 of 9
