Huawei
P30
Huawei P30
f-69b58f9d-f654-400e-b659-5d568eed24e0
f-3bdb3c8d-c6b4-4971-9294-df1e0920f0de
f-f4c4a159-82a3-47cb-a831-994d81e2fc6e
f-eb942c60-a16c-4773-b526-eb0d937d4cee
f-42450ad5-7b2c-4675-800f-20e8ddc44bc9
f-17136568-0500-4cb1-8139-d35e1ae49a28
Can you make a voice call?
