Huawei
P30 lite
Huawei P30 lite
f-a648f297-4545-402e-9e65-2b064453f507
f-bb59445c-d712-4313-90e0-dd01cf95b0c9
f-23c7a06f-ac0c-4878-a3bb-efa4ad144408
f-eb5e20f9-4a39-4b88-b917-3ae9c86be9cd
f-e290a4b3-0987-455d-a343-a561cbb6d640
f-690366ca-8c1c-40b9-a457-b32747b729c6
Solution 11 of 11: The selected network is out of range
Step 1 of 9
Press Wireless & networks.
Step 2 of 9
Press Mobile network.
Step 3 of 9
Press Carrier.
Press Carrier.
Step 4 of 9
Press Carrier.
If you want to select a network automatically, press the indicator next to
Step 5 of 9
If you want to select a network automatically, press the indicator next to "Automatic" to turn on the function.
If you want to select a network manually, press the indicator next to
Step 6 of 9
If you want to select a network manually, press the indicator next to "Automatic" to turn off the function.
Press OK and your phone will search for networks.
Step 7 of 9
Press the required network.
Step 8 of 9
Step 9 of 9
