Huawei
P30 lite
Huawei P30 lite
f-a648f297-4545-402e-9e65-2b064453f507
f-bb59445c-d712-4313-90e0-dd01cf95b0c9
f-23c7a06f-ac0c-4878-a3bb-efa4ad144408
f-eb5e20f9-4a39-4b88-b917-3ae9c86be9cd
f-e290a4b3-0987-455d-a343-a561cbb6d640
f-690366ca-8c1c-40b9-a457-b32747b729c6
Can you make a voice call?
