Huawei
P30 lite New Edition
Huawei P30 lite New Edition
f-c99e242c-702a-40f1-9b5f-d38084b40266
f-5651e181-1124-4072-a855-df82e9eced61
f-6b3ea370-78c1-450f-9f59-e51cf111a771
f-cd4aca61-0b34-4cf2-a32d-a67a828b93ac
f-766244e0-8801-475d-a04e-3df3df914910
f-ba96b406-6f9d-4b4e-9623-1a9a95e58394
Solution 11 of 11: The selected network is out of range
Step 1 of 9
Press Wireless & networks.
Step 2 of 9
Press Mobile network.
Step 3 of 9
Press Carrier.
Press Carrier.
Step 4 of 9
Press Carrier.
If you want to select a network automatically, press the indicator next to
Step 5 of 9
If you want to select a network automatically, press the indicator next to "Automatic" to turn on the function.
If you want to select a network manually, press the indicator next to
Step 6 of 9
If you want to select a network manually, press the indicator next to "Automatic" to turn off the function.
Press OK and your phone will search for networks.
Step 7 of 9
Press the required network.
Step 8 of 9
Step 9 of 9
