Huawei
P30 lite New Edition
Huawei P30 lite New Edition
f-c99e242c-702a-40f1-9b5f-d38084b40266
f-5651e181-1124-4072-a855-df82e9eced61
f-6b3ea370-78c1-450f-9f59-e51cf111a771
f-cd4aca61-0b34-4cf2-a32d-a67a828b93ac
f-766244e0-8801-475d-a04e-3df3df914910
f-ba96b406-6f9d-4b4e-9623-1a9a95e58394
Can you make a voice call?
