Huawei
P30 Pro
Huawei P30 Pro
f-982f8f7a-9045-4996-8a9d-e1e55fe79466
f-0d38148d-b192-417a-af20-c005a90adda9
f-f9cfe359-2909-4037-9371-fc44fb99a323
f-979c6fb8-3eb9-49f3-a8bf-ee656937c558
f-52882f70-b57f-4442-8cd4-75ae181adc70
f-e1726ed1-a2cb-4b4c-bdd9-d8508836fa02
Can you make a voice call?
