Huawei
P40 lite 5G
Huawei P40 lite 5G
f-2a1cacb3-8bdc-4faf-ae12-ecefc097d38b
f-a674966d-ce0f-4a63-8cee-78138fbfe860
f-daea9c61-7a6b-4dfe-a7ae-2c9df301d429
f-26ebb6c4-75a0-4a28-b17b-8fdb06f173f5
f-3264d04f-477f-461d-b3cb-ad992c58e37d
f-15894f03-5d79-4c87-aa7f-f7d16d4eb8ab
Solution 4 of 6: You're trying to check your voicemail when abroad
The default voicemail number can only be used if you're calling from your own network.
Call +447953222222 to check your voice messages when abroad. Please note that you need to set a PIN before you can check your voice messages when abroad.
